(0)| 6/30/2022 9:46 AM | |
Posts: 37 Rating:
Hello, We have other projects in which we use the free telegram, and then add the encoders actual position (r842). But I am not able to select the free telegram in the HW Config of Step7. Mind you: I am talking about a project in Step7, NOT in TIA Portal. I can select the free telegram in Starter, but I am not able to transfer this configuration to the HW Config of Step7. With kind regards, ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 06/30/2022 14:11:34New subject after splitting |
| 7/1/2022 3:29 PM | |
Posts: 37 Rating:
PLC: CPU17-2-DP With kind regards, |
| 7/2/2022 7:41 AM | |
Posts: 8092 Rating:
To best of my knowledge, free telegram i.e. input 17 words & output 12 words is available for CU250S- PN module & not to DP module. Hope this helps. |
| 7/4/2022 10:18 AM | |
Posts: 37 Rating:
Thanks for the information. With kind regards, |
| 7/5/2022 6:10 AM | |
Joined: 5/12/2006 Last visit: 12/19/2025 Posts: 22816 Rating:
use standard telegram 3 or 4 if you need encodervalues |
