1/3/2025 7:39 AM | |
Joined: 1/3/2025 Last visit: 5/23/2025 Posts: 1 Rating:
Hello, After some research i found the patch for wincc flexible 2008 SP5. This patch should fix the integrity problems with step 7 V5.7+ SP1 Integrity problems step 7 V5.7: https://support.industry.siemens.com/cs/ww/en/view/109798574
https://support.industry.siemens.com/cs/ww/en/view/109757233 After installing the patch and starting Step7 V5.7+SP1 again there is no change. There is still the same problem. when i check installed software i can see there is simatic WinCC flexible 2008 SP5 UP2, patch step 7V5.7. Does somebody have exprerience with this problem? And maybe have a solution for this problem? |
1/3/2025 9:17 AM | |
Joined: 7/9/2015 Last visit: 8/29/2025 Posts: 4443 Rating:
Hi, try to update Step 7 V5.7 SP1 to newest Hotfix 4. Download Hotfix 4 STEP 7 V5.7 SP1 / STEP 7 Professional 2021 SR1Regards, Towome |
