(3)| 7/26/2006 10:27 AM | |
Posts: 17 Rating:
Hi, I have Simatic Step 7 Version:V5.3 + SP2, Revision Level K5.3.2.0 installed on my PC. While writing code in the LAD/STL/FBD Programming Block window, it closes without saving after showing error message. I have enclosed the snapshot of the error message. Regards, AttachmentError in Step7.zip (878 Downloads) |
| 7/26/2006 10:58 AM | |
Joined: 4/24/2006 Last visit: 12/24/2025 Posts: 9097 Rating:
Hello, Before the error pops up, what did you do? Is it only in one project or in all projects? Best regards, Wizard |
| 7/26/2006 12:27 PM | |
Hello, Perhaps the following will help: Workaround: in the supplement you find two Reg-files to enable and disable this function. You have to disable the functionality in order to avoid this behavior.
Best regards, Wizard AttachmentXMLCopyPaste.zip (895 Downloads) |
| 7/26/2006 2:18 PM | |
Posts: 17 Rating:
Thank you Wizard, I have run the file and the problem is resolved. Thank you again. Regards, |
| 7/27/2006 8:49 AM | |
Your welcome, Greetings Wizard |
| 8/1/2006 9:42 AM | |
Hello Late, I got it from the Siemens Hotline. Best regards, Wizard |
