(2)| 8/18/2011 1:14 PM | |
Joined: 1/4/2007 Last visit: 12/16/2025 Posts: 1197 Rating:
Hello Abigail, I recommend you to use the Siwatool software. This is the easiest way for you. For the Siwarex M module the Siwatool software is freeware. You can find the Siwatool software on the internet: http://support.automation.siemens.com/WW/view/en/10429779 Into the manual of the Siwarex M module you can find into the chapter 2.2.6 the cable description how to connect a PC with the Siwarex M module. Or you can order that cable from Siemens. The order number is: 7MH4702-8CA. You can find the manual with the cable description on the internet: http://support.automation.siemens.com/WW/view/en/7787784 If you installed the Siwatool software on your PC and you have the cable give me a reply so that I can help you with the adjustment of the scale. Best regards Siwarexi |
