(0)| 2/9/2012 8:11 AM | |
Posts: 8 Rating:
Hello, Adpter is not used (problem is at customer). They have an adapter, but with older PG M, download works with S5 connection cable 6ES5734-2BF00. I didn't check the cable because it workedwith other PG. Sosupposedly it should work with their new PG M3. Or should it ?? Best Regards, Sakke |
| 2/9/2012 9:02 AM | |
Joined: 4/24/2006 Last visit: 12/24/2025 Posts: 9096 Rating:
Hello Sakke79, Could you explain which cable you tried? In my opinion you should use the cable 6XV1-440-2KH32 See this link: What is the serial cable assignment for transferring the configuration to an RMOS operator panel? Best regards, Wizard |
| 2/9/2012 9:11 AM | |
Posts: 8 Rating:
I tried with S5 cable because we first downloaded program with PG M with this cable. I also have 6XV1-440-2KH32availible at my office. I'll try to downloadwith it. Thanks! Best Regards Sakke |
| 2/16/2012 9:18 AM | |
Posts: 8 Rating:
Cable 6XV1-440-2KH32 worked! Strange how S5 connection cable works with PG M but not with PG M3. |
