(2)| 7/5/2011 3:56 PM | |
Joined: 4/29/2010 Last visit: 1/20/2025 Posts: 1557 Rating:
Hello, this is the one you need: What is the serial cable assignment for transferring the configuration to an RMOS operator panel? best regards |
| 7/5/2011 4:03 PM | |
Joined: 4/24/2006 Last visit: 12/24/2025 Posts: 9097 Rating:
Hello, In addition to Sandman's answer. The panel OP17 should be in transfer mode. Here is a link to manual: OP7, OP17 Operator Panel See page 3-5 how to put in transfer mode. (button ESC and UP and power up panel) Best regards, Wizard |
| 7/11/2011 9:20 AM | |
Dear saeedplc, Please have a look at earlier mentioned manual. See page 10-1 to change Language. (Perhaps the following links might help: how do you change the language on an operator panel? Why is the current language set not saved on the operator panel? ) Best regards, Wizard |
| 2/27/2012 8:05 PM | |
Joined: 5/6/2007 Last visit: 12/13/2025 Posts: 31 Rating:
Dear WIZARD I'm unable to access to your link in order to download the pdf file i'm logged with my username and password as you can see i haven't understand what is the problem best regards
Attachmentwizard.zip (397 Downloads) |
| 2/27/2012 8:50 PM | |
Hello, All manuals of the outfased panels are no longer available You will find a manual in pdf here: /tf/WW/en/Posts/69920 Regards, Marcjan |
Last edited by: Marcjan at: 2/28/2012 2:40 PMLast edited by: Marcjan at: 2/28/2012 2:39 PMProblem solved? |
