(0)| 2/2/2007 8:44 AM | |
Joined: 4/24/2006 Last visit: 1/9/2026 Posts: 9104 Rating:
Hi, You will need the following cable: 6XV1 440-2KH32 It's not possible to use MPI Best regards, Wizard |
| 2/6/2007 9:09 PM | |
Posts: 4 Rating:
Hi You can also transfer using RS232, 9 to 15 pin cable (9 pin D type female at your com port and 15pin D type on OP7). |
| 2/26/2007 6:38 PM | |
Posts: 75 Rating:
Somebody have the diagram pin for this cable? |
| 2/27/2007 11:10 AM | |
Hello NewTech, Havea look at the other Thread, /tf/WW/en/Posts/7041 Here I mentioned the place you can find the lay out Best regards, Wizard |
| 3/7/2007 1:27 PM | |
Posts: 75 Rating:
Thanks for your help, now I obtained to find drawing correct.
| 3/7/2007 1:29 PM | |
You are welcome Best regards, Wizard |
