(0)| 1/21/2020 8:10 AM | |
Posts: 1 Rating:
Hello Darius, could you please explain how can upgrade Wincc flexible to Wincc Advanced Tia? ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 01/21/2020 11:55:46New subject after splitting |
| 1/29/2020 9:14 AM | |
Joined: 8/3/2009 Last visit: 12/19/2025 Posts: 16612 Rating:
Hello you can do the migration in one step(then TIA and WinCC Flexible has to be installed in the same System) or in two steps (Then you can use the Migration tool and Flexible and TIA can be on two systems -> LINK) If you have a Comfort Panel you can also check this one: And here are some general Links to information about migration: https://support.industry.siemens.com/cs/ww/en/view/76878921 Bye Murof |
