(0)| 5/11/2020 4:21 PM | |
Posts: 12 Rating:
Thank you for your quick response |
| 5/11/2020 9:11 PM | |
Joined: 3/9/2018 Last visit: 12/31/2025 Posts: 214 Rating:
Not sure the difference on the 3BF20 and 3BF21. I was able to use a FTDI USB -> RS232 converter along with the 3BF21 PPI adapter just fine. See PC/PPI using a usb to serial port Just be aware, as mentioned before, don't set the port on the 22x PLC at 187.5 kbps with a 3BF20/3BF21 adapter. (MicroWin will warn you) After you set the port in 187.5 kpbs mode, you can only access it again with a MultiMaster PPI cable (RS232/USB) or a MPI USB PC adapter. |
