5/3/2024 1:19 PM | |
Joined: 11/12/2021 Last visit: 5/3/2024 Posts: 3 Rating: (0) |
Any update on this? We had issues with some MTP1000 freezing in one application in V17. Now we got another (different) system running V19 and one MT700 in the system froze like the otherone did. Completely diffrent projects and application. In the first project in V17 there is total (4) panels but only (3) MTP1000 that are basiacally a copy of eachother. Only the (3) will freeze randomly but not the MTP1200 which runs different pages etc. Panels should be up to date and time same as PLCs. It's hard to see what could cause that in two different projects. ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 05/06/2024 07:07:46New subject after splitting |
5/3/2024 8:28 PM | |
Joined: 1/21/2013 Last visit: 5/20/2024 Posts: 2798 Rating: (452)
Hi Mgagne99,
I can tell you that several of the causes have already been found and fixed. However, it may take a while for a fix to take effect, as it will be part of the next update. So, as mentioned before, use the latest image version. And reporting problems to technical support will increase the knowledge of the developers and help them find more fixes. Kind regards |
