6/27/2025 12:16 PM | |
Joined: 8/3/2009 Last visit: 10/21/2025 Posts: 16503 Rating:
Hello S.bracke Check also if you hae set up your certificates and run the unified configuration properly: https://support.industry.siemens.com/cs/de/en/view/109806850 Bye Murof |
7/14/2025 12:39 PM | |
Hello S.bracke Which OS do you use exactly (with Build NR)? Do you have tried to install the latest Updates for TIA and Unified RT? https://support.industry.siemens.com/cs/ww/en/view/109963851 https://support.industry.siemens.com/cs/ww/en/view/109963700 Bye Murof |
