(1)| 2/20/2023 8:01 AM | |
Joined: 4/8/2021 Last visit: 1/7/2026 Posts: 642 Rating:
Hi I used the same setup (UPS1600 + UPS1100) once and everything worked correctly. I believe the information you saw in the manual reffers to the UPS1600 with Ethernet/USB interfaces (different MLFB), that can be also monitored using the SITOP UPS Manager software. This is the manual I used then. https://support.industry.siemens.com/cs/ww/en/view/84977415/142086811915 Hope it helps. Best regards. |
