(0)| 5/19/2023 11:56 AM | |
Posts: 6 Rating:
Hallo, can someone help me to solve some IO communication failure. i am making io communication between my safety plc and another device like simotion D445-2 DP/PN, the communication doesn't work and i can't find the reason why? i will add to my topic some picture like alarms message, network view. thank you Attachmentio-communication-failure.zip (960 Downloads) |
| 5/22/2023 3:19 AM | |
Joined: 5/12/2006 Last visit: 1/16/2026 Posts: 22827 Rating:
cpu are in RUN Mode? name and ip are set correct? |
| 5/22/2023 6:59 AM | |
Posts: 6 Rating:
The CPU is on STOP mode. Name and IP-adress are correct |
set both to RUN |
| 5/22/2023 9:16 AM | |
Posts: 6 Rating:
the fplc start and go to run modus with error but d445-2 DP/PN after startup switch back to STOP mode |
| 5/22/2023 9:29 AM | |
check th line with the accesserror then remove this code. and check if simotion go to run, then you can check I/O |
