(1)| 6/12/2023 12:41 PM | |
Joined: 7/19/2022 Last visit: 1/14/2026 Posts: 436 Rating:
Hello Nicolas P. The panel model you mention can be programmed with WinCC flexible Compact version 2004 or higher. You can see it in the technical data of said panel: |
| 6/12/2023 2:47 PM | |
Joined: 4/10/2020 Last visit: 12/17/2025 Posts: 79 Rating:
Hi JBS98, yes, thank you, but i do not have WinCC flexible Compact 2004. What i wonder is if the mention "or higher version" includes other version of WinCC flexible such as Wincc Flexible 2008. In WinCC Flexible 2008 SP3, I can add a TP170A, I guess that it means that it would be compatible, but i just wanted and expert to confirm this fact. |
| 6/13/2023 6:08 AM | |
Thank you very much for your help ! |
