(2)| 10/15/2024 6:15 PM | |
Joined: 9/27/2006 Last visit: 1/1/2026 Posts: 12479 Rating:
Hello Walter; This FAQ shows the possible combinations of HMI available with S7-200 CPUs. Since a CPU S7-200CN is a slight variation on the S7-200 CPU models, this applies to the S&-200CN PLCs in equal measure. The attached screenshot comes from Appedix H of the S7-200 System Manual and describes the relationship between part numbers for the S7-200 and the S7-200CN CPUs. "Which HMI components can you connect with S7-200 CPU and what should you watch out for when doing so?" https://support.industry.siemens.com/cs/ca/en/view/14188898 You will find confirmation that a CPU S7-200 will connect to a TP 177 Micro either through PPI or MPI cables. Hope this helps, Daniel Chartier |
Last edited by: dchartier at: 10/15/2024 18:23:40Last edited by: dchartier at: 10/15/2024 23:05:42 |
| 10/15/2024 7:08 PM | |
Joined: 4/26/2017 Last visit: 10/13/2025 Posts: 78 Rating:
How nice of you to help me that well. Thanks for the info. |
