10/9/2020 4:42 PM | |
Joined: 9/27/2006 Last visit: 9/17/2025 Posts: 12411 Rating:
Hello DariusB; The VIPA SLIO 015 is not quite the same as a CPU 315 from Siemens. There are hardware differences due to the integrated PTP interface that allows Modbus RTU connections, and the use of TIA Portal seems to be rather limited, based on their manuals. VIPA has developed its own functions for serial communications that have no similarities with Siemens implementations of similar protocols. https://vipausa.com/content/manuals/slio/HB300E_CPU_015-CEFNR00_19-22.pdf I suggest you ask VIPA for support on this CPU. Hope this helps, |
2/18/2022 8:27 PM | |
Joined: 9/14/2021 Last visit: 1/15/2024 Posts: 1 Rating:
I have the same problem.Did you find a solution? |
2/28/2022 1:09 PM | |
Posts: 1 Rating:
My problem was solved with fb modbuspn |
12/7/2024 12:04 PM | |
Joined: 12/6/2024 Last visit: 12/7/2024 Posts: 1 Rating:
kindly Share the Reference pics of the backup. |
