(1)| 1/8/2025 6:00 PM | |
Joined: 1/8/2025 Last visit: 1/30/2025 Posts: 7 Rating:
Hi Expert, I want to Copy the CFC Charts from the Zip File to the
Master Data Library. I have steps below i'm trying but no result. Please help me • Select the File > Retrieve command to open the library from the zip file. • In the "Retrieve - Select Archive" dialog box, select the "Sim_lib.zip" archive file and click the "Open" button. Dialog box "Select Target Directory" opens. • Click the plus symbol of the folder to which you have saved your project (S7Proj). Select the "fast" project folder Click "OK". The "Retrieve - Folder exists" dialog box opens. • Click "Rename". The "Retrieve" dialog box opens. • Click "OK". The "Retrieve" dialog box opens once again with a different text. • Click the "Yes" button. Component view "fast_Lib (Component View)" opens. ------------------------------------------------------------------------------------------ |
Last edited by: Moderator_Lan at: 01/08/2025 21:54:59New subject after splitting |
