(2)| 7/2/2009 3:46 PM | |
Posts: 34 Rating:
Hello , Why ET200 Falls when any of its module ( for ex: analog module ) has a fault ? Is it possible to change and make it as it does not fall Bye, |
| 7/3/2009 8:11 AM | |
Posts: 34 Rating:
Hello edr , Thank you for your response If you are sure it will keep continue then its enough for us |
| 7/3/2009 8:43 AM | |
Joined: 3/21/2006 Last visit: 1/10/2026 Posts: 10247 Rating:
Hello Kucuk, Remember also that S7-CPU does not register an insertion or removal (module failure). You can detect such events only by cyclically reading the diagnostic frame and evaluating the module status.. For more info check in SIMATIC Distributed I/O System ET 200S Regards Hristo Mihalev |
| 7/3/2009 9:31 PM | |
Posts: 1742 Rating:
Hello, You can only have a single error in each slave. If you remove for instance two modules in the same slave, it will stop. |
| 7/4/2009 10:32 AM | |
Posts: 34 Rating:
hello lalit , its exactly what i need, we have analog module / channel fail, then et200s fails. how am i gonna figure this out ? bye |
