(0)| 6/25/2025 10:41 AM | |
Joined: 1/21/2013 Last visit: 1/14/2026 Posts: 4400 Rating:
Hi, I'm not sure how you're accessing the byte value. In most cases, it should be a numeric value. However, I know of some parameters that return the value as a string. If that's the case, you can use the Number() or parseInt() function to convert it. Kind regards |
