(1)| 7/3/2014 10:40 AM | |
Posts: 3 Rating:
HI, I have n ANCA Rgx machine , its A axis Rotory motor ecoder failed. i want to replace this encoder , It is a siemns made motor for ANCA. With analog incremental encoder(Heidenhain ERN 1387.001-2048) .. ( I can buy Exactly similar encoder ) I'm not confident that i can replace it , reason is.. I know to replce it mechanically,(By following -https://www.automation.siemens.com/tf/WW/en/Posts/49631 )But i think there is something more than mechanical alignment.what are all things other things i hav to take care about this encoder replacemtn . Kindly help me thanks in advance |
| 7/4/2014 4:51 PM | |
Posts: 4620 Rating:
Hello rjne, I think this type of encoder should be mounted on the series 1PH7 example (1PH7105-2NF02-0BC2). If you say that is equal to the Siemens motors should find some manual maintenance on these motors, but I'm not sure, if I find something I'll tell you |
