11/29/2007 5:03 PM | |
Posts: 271 Rating:
Hello Langley, We've had good experience using the IBS software with Win 98. It's best to run IBS in DOS mode rather than in Windows. You don't need anything special except for the cable connections from your PC. I've attached a recommended cable set up. Make sure that your ground connections on the Simodrive 611 drive is done correctly and make sure that you have a wye-connected line with a grounded neutral. Hope this helps... AttachmentIBSCable.pdf (1032 Downloads) |
