3/3/2006 4:10 PM | |
Joined: 8/31/2005 Last visit: 9/9/2025 Posts: 217 Rating:
Hi sriram! I'm not sure, what your problem is. Could you please explain a little bit more detailed. When you switch on your PLC and it goes to system fault, which entries do you get in the diagnostics buffer of the CPU? Are you able to start a hardware diagnosis via the SIMATIC Manager? What are the results of the hardware diagnosis? All available informations on the CP 343-1 IT (firmware updates, FAQs, ...) you'll find here: http://support.automation.siemens.com/WW/view/en/10806076/130000 |
Greetings, Chris |
