(0)| 7/17/2018 8:51 AM | |
Joined: 1/21/2011 Last visit: 1/13/2026 Posts: 169 Rating:
Dear Expert, We have problem in the IPC 477E is slow in response of the wincc runtime application when ever we click button for popup is taking 3 to 4 sec delay & retrieving of data from SQl also taking time.we have tried same back up in the other PC it is working faster. I have checked all the memory constrain & ram , CPU speed every things look good. Kindly help me to solve the problem. Wincc V7.0 is installed in the IPC. Please find the attached file for the IPC wincc diagnosis file for your references. Regards, Jagan.K AttachmentIPC_Diagonisis Collected File.zip (292 Downloads) |
| 7/17/2018 9:20 AM | |
Joined: 10/18/2012 Last visit: 12/1/2025 Posts: 225 Rating:
Dear Jagan.K, what type of operating system do you have? Can you provide the exact type-no. of your ipc? Maybe the bad click reaction time results from an unfixed hidlock process. See Case 3 at https://support.industry.siemens.com/cs/ww/en/view/109752279 for details. regards, |
