(0)| 1/17/2009 11:26 AM | |
Posts: 4 Rating:
Hello! Try with http://support.automation.siemens.com/WW/llisapi.dll?func=cslib.csinfo&lang=en&objid=18467424&caller=view You can initialize value("WR_Job_value") with bit "WR_Count_value". Best regard |
| 1/18/2009 10:01 PM | |
Posts: 4 Rating:
Hello! The easiest way is that you download this example http://support.automation.siemens.com/WW/llisapi.dll/csfetch/18467424/FBCount31xC.exe?func=cslib.csFetch&nodeid=21921212 and instead of using SFB47 you use FB1 from example. (look picture). To keep counter value after restart PLC, you should in OB100 write counter value to DB50.DBD4 (from my example on the picture) and set bit DB50.DBX12.1. Best regards |
