9/10/2025 8:12 AM | |
Joined: 8/3/2009 Last visit: 9/10/2025 Posts: 16386 Rating:
Hello Alijon_1993 you have not mentionend which HMI device you are exactly use for the OPC UA Client. Have look at this examples, there are a few combinations available. At least the client side should be explanied for your case: https://support.industry.siemens.com/cs/ww/en/view/63481236 If you have a Unified System then it could work slighliy different. But then we would need a few more information Bye Murof |
