4/3/2020 12:48 PM | |
Joined: 2/22/2020 Last visit: 1/6/2024 Posts: 19 Rating:
i am using step 7 microwin v4 |
4/3/2020 12:53 PM | |
Joined: 3/5/2014 Last visit: 8/5/2022 Posts: 5521 Rating:
okay, but you are posting in Step7 TIA-Portal.... (I ask the mod to move the thread) have you tried to install the latest update? STEP7 MicroWIN V4.0 SP8 and SP9regards, |
FCK WAR! |
4/3/2020 3:13 PM | |
I am using window 7 ultimate 64 bit Plc cpu s7 200cn Microwin version 4 Adapter - Pc adapter USB a2 |
4/3/2020 4:00 PM | |
Joined: 9/21/2012 Last visit: 9/17/2025 Posts: 4714 Rating:
Microwin 4.0.9 is not compatible with Chinese version of S7-200 Smart CPU's. |
4/3/2020 4:52 PM | |
Joined: 9/27/2006 Last visit: 9/17/2025 Posts: 12411 Rating:
Hello Hati; S7-200 CN PLCs are basically the same as S7-200 CPUs, except they were designed for the Chinese market. There is even an appedix added to the S7-200 System manual describing the specific parts of the S7-200 CN modules. What caused problems with standard (european) S7-200 programmers was that the existing versions of Step 7 Microwin v4.0 (SP2 and lower) could not program these new CPUs, but also that with Microwin 4.0 SP3 and higher you needed to set the Windows operating system language to Chinese if you wanted to acces these CPUs and program them.
The CN family of S7-200 PLCs was discontinued in 2017. S7-200 SMART CPUs are another family of processors entirely, designed for the South-East Asian market, and maintained by the Siemens India division. They are programmed with MicroWin SMART software, they have an on-board Ethernet port, can use signal boards... https://new.siemens.com/in/en/products/automation/systems/industrial/plc/simatic-s7-200-smart.html I retraced this document on another automation site I participate in occasionally discussing S7-200 CN issues. http://www.plctalk.net/qanda/showthread.php?t=31705 Hope this helps, Attachments7200 system manual_Appendix H_CN CPUs.pdf (462 Downloads) |
