5/8/2006 10:10 AM | |
Posts: 5822 Rating:
Hello, my STEP7 calculated the following: as you see there is a slight difference to the calculations you did with the watchdog time. Is it possible for you to put all Stations, at least seen form the HW Configuration, into one Project? The PLC Program can be outside this Project, just to make sure that all Stations have the same and valid Bus configuration. Best regards J_Bell AttachmentBPSet.zip (1090 Downloads) |
