(0)| 4/24/2018 8:59 AM | |
Posts: 61 Rating:
Thanks for the answer. ACB Part no. is - 3WL1208-4CB38-1AA2 Also note that the safety requirement for circuit is PL 'd", Catagory 3. Kindly provide sample calculation if possible. I have attached backup calculation for the same. AttachmentVSD with STO Function.zip (1330 Downloads) |
| 4/24/2018 10:16 AM | |
Posts: 43 Rating:
You find the safety values for 3WL here: When the set-up is identically as in your SET example calculation you can replace your 3RT with the 3WL switch. Choose 'Third-party manufacturer' and 'Faultrate calculate with a B10d value' then. Best regards SET Team |
