(0)| 4/9/2025 7:47 PM | |
Joined: 1/21/2013 Last visit: 1/14/2026 Posts: 4400 Rating:
Hi levi_marshall099, Unfortunately, I’m not as experienced with WinCC Unified PC Runtime as I am with WinCC Unified Comfort Panels. However, according to the manual, Microsoft SQL support must be enabled during installation. When switching to Microsoft SQL, existing SQLite instances are not deleted, but they will no longer be usable. Also, by default, a simulation will still create SQLite instances — which could explain the behavior you're seeing. Kind regardsStefan |
| 9/26/2025 5:20 AM | |
Joined: 8/3/2009 Last visit: 1/9/2026 Posts: 16629 Rating:
Hello levi_marshall099 if you want to use a manual SQL Server connection from Javascript you can do so: https://support.industry.siemens.com/cs/de/en/view/109806573 Bye Murof |
