(0)| 4/19/2021 3:16 PM | |
Joined: 6/22/2017 Last visit: 12/17/2025 Posts: 424 Rating:
Hi, it does not matter if you use a Panel or PC there. But it clearly shows, that for the definition it is possible (and should be done in your case) to use a plc data type. It has to be versioned in the library. Then you can define a tag in the tag table with the same data type and connect it in the definition. Else, see: https://www.youtube.com/watch?v=zD_wm6OWOJs I hope this helps |
| 6/16/2021 12:27 AM | |
Joined: 2/21/2019 Last visit: 10/22/2025 Posts: 3 Rating:
Hello, I have the same problem. What solution did you find to solve this problem? Best Regards |
