7/21/2021 6:21 AM | |
Joined: 4/23/2010 Last visit: 12/31/2023 Posts: 8092 Rating: (872)
Hello, The best way to come out of this problem is, please check MLFB & serial number of CCU. From it find out, installed system software version, PLC & HMI details. Search availability of software & hardware i.e. CCU card. Siemens Sinucopy FFS with PG/PC & interafcing cables is required so that user can copy system software & load it on CCU card. For this you can either get help from Siemens support center or system house or OEM or an expert easily available to your area. P.S. - 6FC5250-0AX00-0AB1 - It is SINUMERIK FM NC/840D/DE technol. cycles turning Milling, drilling copy license MLFB number |
7/21/2021 10:44 AM | |
Hello, Please refer 6FC5410-0AY01-0AA0 this page you will get information about PLC & NC details. For system software you can contact directly to Siemens, please check your local Siemens support center here. BTW which is your location? You can check spare CCU availability on internet & check if any supplier can supply system software e.g. check CCU1 availability here. Please ensure a supplier who can supply CCU1 with correct system software & can install the same on CCU. Unless & until you get complete support, it will not be of any use. |
