1/10/2022 3:08 PM | |
Joined: 8/3/2009 Last visit: 9/17/2025 Posts: 16447 Rating:
Hello Tobias, I Think you cannot compare your Solution (TIA Portal) to the Way in WinCC flexible with Simotion PLC. I would check the FAQ: https://support.industry.siemens.com/cs/ww/en/view/24109937 Bye Murof |
