3/22/2022 12:01 PM | |
Joined: 3/8/2022 Last visit: 3/22/2022 Posts: 2 Rating: (0) |
I want to share the screenshots of the image files received. Can you please clarify wheter it is the correct files. Can you guide us the proper way to restore these files. Normally ghost files should be in gho format to restore the whole HDD. I have attached also the screenshot of the gh files, ( using Ghost image explorer, we can view what is the content of the image files.) ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 03/22/2022 12:09:59New subject after splitting |
3/22/2022 12:34 PM | |
Joined: 4/23/2010 Last visit: 12/31/2023 Posts: 8092 Rating: (872)
Hello, Yes GHOST image file has extension of .GHO. From the attached snap it looks like PCU 50 has WinNT base software which you can confirm from your PCU50 name plate. Since I have never worked on WinNT I am not sure about ghost image file extension. Please refer PCU 50 Win NT: Restore disk or ghost image - Entries - Forum & /tf/WW/en/Posts/50934 which may help you. |
3/23/2022 5:19 AM | |
Joined: 10/4/2017 Last visit: 4/21/2024 Posts: 40 Rating: (3) |
Dear PISCEAN 2010, This is one important observation that I found confusing. Please refer to the image attached. The PCU 50 nameplate shows that it's equipped with WinXp embedded Pro! And before you rush into judgement, I confirm to you that the original hard disk had the same service desktop windows(WinNt). |
3/23/2022 6:22 AM | |
Hello mattar1989, Again twist is, it is 840Di & not 840D or do not know if anybody has used 840Di system PCU in your machine. Not sure. I suggest you to contact your OEM & get it clarified. Lot of confusion, first is it WinXP or WinNT? Second GHOST image? Third problem is any hardware modification adopted just to keep machine running? fourth you facing on Y axis drive problem. So it's better to get it resolved from OEM or if not possible get help from local Siemens service support. |
3/24/2022 5:30 AM | |
Thanks again for your advise. I agree with you about all the confusion in this machine. I have ordered a replacement HDD from OEM through it's service partner. They will get the ghost images from another working machine. I don't what would be the OS on that PCU50. |
