6/1/2022 9:26 AM | |
Joined: 3/5/2014 Last visit: 8/5/2022 Posts: 5521 Rating: (1050)
hi umd_ee, have you measured the current on the channels, if the value is correct? Do you have the all the same devices(transducers) on your current channels? There are two possible current transducer that can be used with this module: Measuring methods and measuring ranges of SM 431; AI 16 x 13 Bit 2 wire sensors get thier supply through the measuring wires. 4 wire sensors get thier supply elsewhere. I guess your sensors that doesn´t work have thier own supply and therefore they are 4 wrie sensors. If this is so, you need to switch the Measuring range module settings to C for this channel. hope this helps, regards, |
