(0)| 5/30/2022 2:21 PM | |
Posts: 3 Rating:
WinCC OA - error when try to configure the ORACLE DB for RDB with way_of_backup set to datapump value - OS Linux CentOS 7, If I run the unix_install.sh with way_of_backup set to datapump value I get the error (see the log attached). What should I do to make the script work with way_of_backup set to datapump value (as recommended)? Thank you. AttachmentRDB_setup.txt (897 Downloads) |
