10/10/2022 3:06 PM | |
Joined: 7/7/2010 Last visit: 7/29/2024 Posts: 15015 Rating:
Perhaps searching for V90 F7995" in these forums may help. If you choose, you may run across this forum topic: V90 Profinet start up problem - 185497 - Industry Support Siemens It may help clarify what is going on, or at least make you think about requesting warranty support from the equipment supplier - since this has been an on-going problem. Might be due to mechanical wear, timing of logic driving the motor (from PLC or other device), or perhaps there is something working loose like an encoder coupling. I suspect only one of these is actually a cause for F7995, so please do search these forums for all the related information instead of waiting on others with specific V90 fault knowledge from happening onto these forums, read your post, and have time to reply.
science guy |
