3/16/2023 11:17 AM | |
Posts: 1 Rating:
Hello, I am using the OPC UA Server from OPC UA server model via Nodeset XML because this is the only way I've been able to reliable run an OPCUA server on the IOT2040 without coding my own. Now I have the problem when I'm trying to write Values to a node via Node Red's OPC UA Client I get following error :"warning ns=2;s=S7.MyBOOL;datatype=Boolean has no _timestamped_set_func" on my OPC UA server and I don't know how to fix it. I couldn't find anything to that error message online. Any help Would be appreciated. Kind regards, Jan .-. ------------------------------------------------------------------------------------------ |
Last edited by: U_163ab0b5-1d1b-4c1d-b8a8-022ebd79c97b at: 03/16/2023 13:18:29Last edited by: Jen_Moderator at: 03/17/2023 07:45:02New subject after splitting Last edited by: U_163ab0b5-1d1b-4c1d-b8a8-022ebd79c97b at: 03/17/2023 08:19:58Last edited by: U_163ab0b5-1d1b-4c1d-b8a8-022ebd79c97b at: 03/17/2023 08:21:18 |
3/23/2023 12:40 PM | |
Joined: 4/28/2015 Last visit: 4/24/2025 Posts: 3345 Rating:
Hi, I haven't found anything online as well and don't know what this error means. You can maybe reach out the the node-opcua github page. The server in this example is based on node-opcua. Best regards! |
