9/20/2023 11:47 AM | |
Joined: 7/19/2022 Last visit: 11/8/2024 Posts: 419 Rating: (71) |
Hello eltiu, F31110 appears due to errors in communication between the encoder and evaluation module. Therefore, as you mention, it is possible that this is due to electromagnetic disturbances. I recommend you check the functional ground. Functional ground is used to divert electromagnetic interference voltages to ground. This improves resistance to interference in data transmission. The functional ground is used to ground the cable shield and device case, thus diverting any interference pickup to ground.
