6/7/2009 12:11 PM | |
Joined: 7/16/2006 Last visit: 1/2/2024 Posts: 1502 Rating: (176)
Hi O.K. 're the chef
Load from this Link https://www.automation.siemens.com/doconweb/content.asp?item=3141&cd=sinumerik_simodrive_04_2009_e&scope=all a dokument with the name "Start-Up Guide 840d/ . . . " Goto Side 245 Capter 11.8 If you have ask --> Forum I hope that help you. |
Karl |
6/8/2009 5:26 AM | |
Joined: 3/3/2008 Last visit: 10/5/2023 Posts: 333 Rating: (51) |
hi this is a common error.. i would like to know whether your pc i on domain? if it so remove it and work under work group. also create a new user in windows called AUDUSER and give the password as SUNRISE..this also helps. try to diable the winodws firewall and antivirus also. try to follow the procedure attached withr regards Ram AttachmentProcedure for loading image using network.pdf (516 Downloads) |
12/19/2023 6:08 AM | |
Joined: 1/17/2018 Last visit: 5/3/2024 Posts: 12 Rating: (0) |
Hi What software do you use to make the images after you have taken the harddrive out? |
