(0)| 2/20/2024 2:40 PM | |
Joined: 5/6/2022 Last visit: 1/14/2026 Posts: 589 Rating:
Hi modjla, Are you communicating the PLC with any WinCC Unified? I tell you this because this message usually occurs when this communication is made. Check out this FAQ that I share below that shows the same message in the diagnostic buffer as you: If it is not helpful, can you explain your architecture and if you communicate the PLC with other equipment? Best regards! |
