6/14/2024 12:20 PM | |
Joined: 12/16/2021 Last visit: 6/20/2024 Posts: 1 Rating: (0) |
Hello, I am currently using Sistema but I'm struggling to find a component on the VDMA file. I have checked on your website and its not been superseded or anything like that. is there a procedure where this can be added? Regards Michael. ------------------------------------------------------------------------------------------ |
Last edited by: The Helping Hand at: 06/14/2024 13:50:36New subject after splitting |
6/17/2024 2:12 PM | |
Joined: 4/17/2009 Last visit: 6/17/2024 Posts: 302 Rating: (57) |
Hi Michael, thank you for your question. The current Siemens VMDA library can be downloaded from the following link: https://support.industry.siemens.com/cs/ww/en/view/109750403 To integrate the VDMA library in Sistema you can proceed as follows: Edit-> VDMA Library-> Add Library-> Choose the Siemens VMDA Library .xml file After that you can search inside the Library for the right component. To integrate the
device into your project there are two ways:
If you don´t find the component in the Siemens VDMA library please describe in detail which component you are searching for. |
SE Support |
