(0)| 1/9/2024 6:40 PM | |
Joined: 5/6/2022 Last visit: 1/15/2026 Posts: 589 Rating:
Hi Swany, It seems a very strange behavior indeed. From what I understand from your post, this problem only happens to you if you have selected/set something giving it a Pallete color, right? If you select a normal non Pallet color, does it show correctly in the Client? What I would recommend to test is to update the version of WinCC V8 to the latest possible version, in case this behavior has been corrected: "Updates for WinCC V8.0 and WinCC V8.0 ASIA" If not I would create an SR to Siemens Support in case it is some kind of bug or something.... Best regards! |
| 2/2/2024 11:59 AM | |
Posts: 8171 Rating:
New question published by MustafaQandeel is split to a separate thread with the subject WinCC client shows wrong black color when importing color palettes from the server.. Best regards |
| 9/25/2024 8:14 PM | |
Posts: 1 Rating:
I think this is relevant in WinCC 8.0 update 5 check readme page 41 https://support.industry.siemens.com/cs/ww/en/view/109818723 |
