(0)| 10/21/2024 11:07 AM | |
Joined: 5/6/2022 Last visit: 1/15/2026 Posts: 589 Rating:
Hi martin_walker88, In this case, I believe that until the image window is called, the script is not executed. So, it occurs to me that maybe you could use the invisibility/visibility of the object to cause the script to run. I hope this idea can help you. Best regards!
