(0)| 10/23/2024 11:58 AM | |
Posts: 1 Rating:
Hello, I need to make a combo box which will display multiple text tags. Please help |
| 10/24/2024 11:26 AM | |
Joined: 7/10/2024 Last visit: 1/16/2026 Posts: 180 Rating:
Hello! Try taking a look at the following FAQ that exists in SIOS. It might be useful to you if it's the WinCC you use. - Dynamic text lists in WinCC Comfort/Advanced I hope it helps you. |
Last edited by: Moderator_Lan at: 10/24/2024 12:17:07link optimized If you found this post helpul, I'd greatly appreciate your feedback with the rate function |
| 10/29/2024 8:09 AM | |
Joined: 8/3/2009 Last visit: 1/16/2026 Posts: 16641 Rating:
Hello AutoGen_380475 you can use a Combobox and fill it wih a Script: https://support.industry.siemens.com/cs/ww/en/view/28921535 (you do not need to use multilingual like in the FAQ, you can ue any information) Bye Murof |
