(0)| 1/4/2025 10:23 AM | |
Joined: 1/4/2025 Last visit: 1/14/2025 Posts: 2 Rating:
Hello, I've standard S7-1200 CPU 1214C (6ES7 214-1HG40-0XB0 , firmware V4.2) and I want add SIPLUS 8 analog input module 6AG1231-4HF32-4XB0 but in TIA Portal (V14 SP1 Update 10) I cant do this ( red prohibition sign appears ). What I should to set in TIA Portal that I can add this SIPLUS module to standard CPU? Thank you in advance and Happy New 2025 Year! |
| 1/4/2025 10:47 AM | |
Joined: 9/21/2012 Last visit: 12/29/2025 Posts: 4832 Rating:
You select the module the Siplus module is based on and add that to the config. |
| 1/5/2025 6:29 AM | |
Can you explain other word, becouse i dont understend. I drug and drop 6AG1231-4HF32-4XB0 but I can not drop it (red prohibition sign appears) Is it at all possible to use a SIPLUS module for a standard CPU? |
