(0)| 2/11/2025 11:36 AM | |
Joined: 7/11/2024 Last visit: 12/30/2025 Posts: 200 Rating:
Hi pouria89, Have you previously installed Wincc in this computer? When WinCC is removed , the "WinCC" SQL server instance remains installed and must be removed manually for licensing reasons. Also, you should check that your system meets the hardware requirements to perform the installation of WInCC 7.3: Hardware Requirements for the Installation I hope this helps you! 😊 |
If this post has been useful, don't forget to rate it!😊 |
