(0)| 2/19/2025 1:13 PM | |
Joined: 5/29/2024 Last visit: 12/26/2025 Posts: 123 Rating:
Hi! In the following FAQ you can find a guide that shows indications in roder to create faceplates. In the section named "Set up the pop-up faceplate" you can see how to configure it as a popup. In page 43 explains how to close it: -> Tips and tricks for configuring faceplates with WinCC Unified Hope it helps! |
