(0)| 1/25/2010 10:31 AM | |
Posts: 535 Rating:
Dear chilibangcarne, did you set the 'CPU contains safety program' checkbox in the protection-tab of the CPU? Best regards, yy1 |
| 1/25/2010 1:31 PM | |
Joined: 10/7/2005 Last visit: 1/16/2026 Posts: 3054 Rating:
Hello chilibangcarne you can find plenty of good application examplesat the link below: Distributed Safety ApplicationExamples Apart from that, you should find shortcuts to the"Getting started guide" as well as the full Programming manual in the "Documentation" folder of your "Simatic" program group from the Start menu (I highly recommend going through these if this is the first time you work with Distributed Safety). I hope this helps |
Cheers |
