(0)| 11/29/2010 6:20 AM | |
Posts: 3 Rating:
Dear Admin. I'm new comer on siemens, and i joint to one of company, we have 2 CPU 315- 2DP and 6 ET 200, it complited wire, how i can upload the program insite to my PC? Rgds Nur Attachmentplc turbine.pdf (337 Downloads) |
| 11/29/2010 7:08 AM | |
Joined: 3/21/2006 Last visit: 1/10/2026 Posts: 10247 Rating:
Hello Nur, Start Simatic Manager - > Upload Station to PG...Just look at SIMATIC Programming with STEP 7 V5.5 (Chapter 19.3)\ Just to mention that upload project doesn't content any symbol information. Best regards, Hristo Mihalev |
| 11/29/2010 10:01 AM | |
Posts: 3 Rating:
I tried n still problem wit my MPI usb adapter, the led power not light. When i switch on the power supply, the sop light blinking. I need more advice. Rgds Nur |
| 11/29/2010 10:08 AM | |
Hello, Did you install USB/MPI Adapter properly? - What should you watch out for when installing the USB PC adapter? And in PG/PC Insterface did you set PCAdapter(MPI) with correct settings? Best regards, Hristo Mihalev |
| 11/30/2010 1:45 AM | |
Posts: 3 Rating:
i already use my MPI USB on Simatic S7 200 and working done, what different setting of this USB to S7 300 ? Rgds Nur |
