(7)| 10/13/2011 3:00 PM | |
Joined: 9/23/2005 Last visit: 1/14/2026 Posts: 4448 Rating:
Hi, PLC (system) alarms have numbers. This numbers could be unic for each cpu (new and popular mode) or for a holeproject. Take a look at: "What is the difference between CPU-wide messages and project-wide messages and how do you configure symbol-related messages?" http://support.automation.siemens.com/BR/view/en/16993580 |
Denilson Pegaia |
| 10/27/2011 12:22 AM | |
Joined: 3/4/2006 Last visit: 11/24/2025 Posts: 73 Rating:
Thank you, I was running into the same problem. |
| 10/27/2011 1:23 PM | |
Joined: 1/25/2006 Last visit: 11/27/2025 Posts: 257 Rating:
Hi,I solved problem with migration project... You have to do the next: To change an existing project from project wide to CPU wide. Open the project in Step7 5.x. Select: Options --> customize... --> message numbers Choose "Always assigne CPU oriented unique message numbers...". Afterwards save your existing project under a new name, with the option "reorganization slow". Now the message number method was changed in this project and you can migrate to Step7 V11. |
